MOPAR4Me
Was hoping for some help on which mechanical fuel pump I can use on my Magnum 360 swap.
I have airgap type intake, stock 1994 Magnum bottom and top end along with original cam.
I already swapped over my LA 360 timing cover, chain, water pump, pulleys, etc.
I have also aded the cam snout extender with eccentric.
So all I am trying to figure out specs on which mechanical fuel pump will work best on this setup.
I am using an eddy 604 performer series, 600 CFM carb.
Will a stock oem 360 fuel pump work. If I am not mistaken those run anywhere between 6-7.5 PSI at around 30 GPH
I read somewhere that the Magnums with airgaps like to be more around 4-5 PSI, any truth to that?
Thanks.
Thanks.
