What gear should I use
What size gear should I use with 29” tall tire. 8 3/4 360 magnum with single turbo. Thanks
For what purpose?
29s don't fit on any A-body without a lotta work; so 29s imply track-time.
with what trans?
at what weight
and altitude
and stall?
What speed are you expecting to trap at?
I like Rusty's reply
For what purpose?
with what trans?
at what weight
and altitude
and stall?
Yea the back end has been done to fit 29x18.50. Mostly street with some race time. It has a 727 not sure on the stall was waiting to see what gear to get first. 3200# Dodge Dart with 360 magnum and single turbo.
If a street car 3.73 at the least. 4.10 to 4.56 likely.
That is a tall tire! If multipurpose then some compromise is in order.
I would think 5.? if you intend more time on the strip! The Convertor stall answer will help as well the overall weight!
