alex perini
Active Member
When is it necessary to install arp studs in the 440 lower end mains building mild street 440 will stock bolts hold up ?
I would like to see the science of that. All a stud is is a bolt with a nut on the end instead of a hex head. They both do the same thing. No?The biggest improvement you can make on any stock block is main studs. The RB blocks being as weak as they are will benefit more so than most. With studs the caps are being pushed into the block instead of being pulled like with bolts. This destrsses the main area of the block where RBs have problems.
With a bolt the torque is transfered to the block, and the bolt pulls the cap down. With studs the torque is applied to the nut, and the cap is pushed into the block.I would like to see the science of that. All a stud is is a bolt with a nut on the end instead of a hex head. They both do the same thing. No?
Sorry Tim, I got interrupted.
Studs also have other advantages. The torque on a bolt only applies about 10% of it's force to clamping. The other roughly 90% is used up overcoming friction (thread engagement, bolt twist, ect). Studs not only apply way more clamping force, but the torque values are way more accurate due to the fine thread for the nut and quality of the machining. That increase in clamping force helps stabilize the block. In many cases crank walk can be completely eliminated using studs.
In some oval track classes where OEM blocks are required studs make a huge difference. The additional clamping force and destressing of the block not only let the block live longer, but can help a cast crank(lighter weight) live. Most crank failures have nothing to do with the crank. It's the block flexing that wipes the crank out. When people use a forged crank they usually don't realize that the benefit is that a forged crank can flex better than a cast crank.
I've never had to. You will need to chase and clean all the threads well though as studs should bottom out in the hole. I've also seen many times where the factory didn't tap the threads all the way to the bottom. That should be addressed prior to install. Also don't forget to use the supplied lube. This cuts friction to increase clamping force.Do you have to enlarge the main cap hole slightly to install studs or just line hone? Thanks!
In some applications it may be necessary, but I've never had to. The registers align the cap, not the stud. I have had to enlarge holes on windage trays though, and play games with washers to get the spacing right.Ok. I heard you had to. I’m gonna use studs even though it’s probably overkill for my build. Better safe than sorry. Thanks!
Thank you..Sorry Tim, I got interrupted.
^^^^^^^^^^^^^^^^^^I would like to see the science of that. All a stud is is a bolt with a nut on the end instead of a hex head. They both do the same thing. No?
What kit are you guys using for studs ?
Grade 9 from a good hardware store? I never thought of that...I have also used grade 9 bolts were $ is a issue, grade 8 are 150.000 psi tensile and
grade 9 are 180.000 psi tensile strength and they are about $5 ea
