Can you get the bushings out to replace, or are these just throwaway starters?Do they have brush keepers to hold the brushes back for reassembly, like the older designs?
Is there a thread on wiring a mini starter up? Sorry I cant search , Im at work and not all forum functions work properly. But say going from a gear reduction starter to a mini, what is the wiring schematic?
Is there any difference between the Mopar Performance mini starter and the stock truck mini starters??? Or are they the same????
How easy are they to rebuild?
Normal wear parts like clutch, contacts, and brushes are readily available?
How are they at -15 degrees F?
If someone knows where to get parts for these, I'd like to hear. NAPA knows nothing. Last I heard, they were pretending to be an "auto parts store." I've got two that both have slipping clutches.
NAPA is about as good as you can get, a
Besides that.
Are they the same size physically?
