What is this called???
Chris Biggs
Northern Virginia
Trying to replace the wiring that goes to my fender mounted turn signal in my 66 Barracuda. What is this called? I just need this because, with the one I have, the base where the bulb sits has broken off and I can't re-crimp it.
Any help will be appreciated.
so..whats it called officially? Looks like a pressure line fitting with an electrical bullet splice on the end?
I'm still not sure, I just ordered the one off of ebay. I could've done the wiring, but I couldn't find the base that contacts the bulb to send the electric signal to it.
That there should be it. The "socket" in the indicator housing is male threaded. The bulb fits in like a .22 cartridge, and this thing screws on and makes the ground for the bulb as well as the "hot" contact for the wire
