What is this for?
Mopar General Discussions
  1. gtxdude
    gtxdude Well-Known Member
    480
    209
    Apr 30, 2011
    Bloomington, MN
    Local Time:
    12:53 AM
    My neighbor found this in his car and wondered if I knew what it was for. I did not, thought I would post it and see if anyone knew. plyers.jpg
  2. Streetsboro Rick
    Streetsboro Rick Well-Known Member
    164
    67
    Apr 27, 2018
    Streetsboro Ohio
    Local Time:
    1:53 AM
    Cheap oil filter wrench
    • Agree Agree x 10
    • S'cuder
      S'cuder FABO Gold Member FABO Gold Member
      407
      358
      Nov 30, 2013
      Upstate
      Local Time:
      1:53 AM
      Oil filter wrench.
      • Agree Agree x 5
      • Heywodja
        Heywodja The Heartbeat Stops Here. FABO Gold Member
        546
        210
        Aug 16, 2014
        Texas
        Local Time:
        12:53 AM
        If it flew out from the undercarriage and poked a hole in the oil pan, it could be the most expensive oil filter pliers in the world
        • Like Like x 3
        • Agree Agree x 1
        • MoparMike1974
          MoparMike1974 FABO Gold Member FABO Gold Member
          2,630
          1858
          Jun 16, 2017
          Maryland
          Local Time:
          1:53 AM
          They work good in tight places. Only good for removing since they usually damage the filter.
        • diymirage
          diymirage HP@idle > hondaHP@redline
          20,310
          14684
          Oct 12, 2012
          michigan
          Local Time:
          1:53 AM
          fixed it for ya
          • Agree Agree x 2
          • pishta
            pishta I know I'm right....
            18,266
            7741
            Oct 13, 2004
            Tustin, CA
            Local Time:
            10:53 PM
            easier to use than a stupid can or strap wrench to take the filter off. More leverage too. Filter destroyer....
            • Agree Agree x 2
            • S'cuder
              407
              358
              Nov 30, 2013
              Upstate
              Local Time:
              1:53 AM
              They work good in tight places. Only good for removing since you never want to go more then fingertight on a filter .
              3/4 to 1 full turn after gasket contacts base, even if that means using a filter wrench. Not a filter destroyer wrench, obviously. Some filters even have an illustration on the side, and handy numbered reference points every 90°.
              Around 1990, I had an old timer for an oil customer, who has since passed away. He always insisted "hand tight." Our filters were made by Purolator, because Pennzoil owned them at the time. He installed one of our filters on a 302 Ford, which leaked, and the engine blew. He put in a claim, and our tech people tested the filter to 100 PSI. The claim was denied, because the filter didn't leak. The failure was blamed on incorrect installation. I lost the account, but got it back a year or so later, but oil only.
              Moral of the story: If you don't crank that sucker down a full turn, don't blame the filter when it leaks at the gasket.
              • Like Like x 2
              • diymirage
                20,310
                14684
                Oct 12, 2012
                michigan
                Local Time:
                1:53 AM
                i like to use these to remove them, gets you in tight spots since you can put as long an extension on as you need
                i like to take mine apart and put a bunch of axle grease on the gears so the fingers dont open as you try to put it on
                interesting
                ill keep that in mind
                honestly never noticed instructions printed on oil filters
                • Like Like x 1
                • Agree Agree x 1
                • pishta
                  18,266
                  7741
                  Oct 13, 2004
                  Tustin, CA
                  Local Time:
                  10:53 PM
                  3/4 -1 turn past gasket contact is pretty tight. you cant usually get that with a greasy hand unless its a POS Fram ultra guard "grip tape" model.
                  • Agree Agree x 1
                  • my5thmopar
                    my5thmopar Life Long MOPAR Owner FABO Gold Member
                    1,251
                    548
                    Jul 15, 2011
                    Tennessee
                    Local Time:
                    12:53 AM
                    Also good for pool filter pipe remover or jar opener and the larger radiator hoses.
                  • Cope
                    Cope Fusing with fire
                    4,389
                    5274
                    Oct 20, 2009
                    San Jose, Ca.
                    Local Time:
                    12:53 AM
                    I drive a flat head screw driver through the filter and twist em off when they get stuck.
                    • Agree Agree x 1
                    • 75slant6
                      75slant6 Well-Known Member
                      5,360
                      1868
                      May 15, 2011
                      Russellville, ky
                      Local Time:
                      12:53 AM
                      I worked for a mechanic for awhile that had the same thing happen. He use to just hand tighten filters until he had one back off and blow a Diesel engine. He ended up buying and installing a new engine on his dime. After that he always put em on finger tight plus 1/4 turn.
