What is This?
delt127
Member
Nashville, TN
Title says it, what is this?
It was in the trunk when I bought the vehicle.
Thanks.
I actually have two parts that look the same but differ in the part numbers cast into the body of the pump.
Part #1: 210410 (side); then 010, 70D, and 2C on the end
Part #2: 210117 (side); then 010, 70D, and C9 on the end
Casting numbers are not necessarily part numbers.
Lares has a tag with the part number:
The numbers I came up with on a quick search are 11031 and 11033, which have pitman shaft diameters of 1.25 and 1.12" respectively.
There is also an 11043 box, which is a quick ratio version of the 11033 box (10:1).
