What is this..?
nodemon
St.Louis
What is this for..? Wire harness..?
Anyone have a pick of what goes in that...factory pic..?
It should be rolled against the firewall capturing the brake line. Then closed around the cable with the gap towards the column.
Alan
It should be rolled against the firewall capturing the brake line. The closed around the cable with the gap towards the column
What year is that on?
Mine's a 67 and I replaced the batt wire. The oe part was held as you see in my photo.
I'll have to look at mine closer.
What you showed makes sense!
