What kind of upper Leaf spring bushings to get?
hoop
Kentucky 40862
Going to be putting new leaf springs on my 72 Dart with 318, I have the Adjustable Shackles, so just be getting bushings only!.. So I was wondering What kind of rear upper Leaf spring bushings to get?... looked at ones on autozone & they say 6cl, So what brand & best place to get right bushings I need?
If I was going to be running adjustable shackles I would opt for the delrin bushings from PST, since they are a bit stiffer that rubber and stand up to the side flex a little better.
Non adjustable shackles I would run poly also from PST.
I got some new ones from rockauto.com, the lower ones seem right, but the upper ones are too big!... Can some one tell me what upper ones I need & wear to get?... As you can see in my pic I need the upper one's with metal on the outside, wear mine are rusty!
Those rear springs do not have the stock parts and that’s what you should get with or without new springs. New shackles!
