What pedals fit in a 69 barracuda?
92b
Breda,Iowa
Slowly acquiring parts to convert my 69 barracuda from automatic to 4 speed. What year and models will fit in my 69 barracuda? If there is a thread that already covers this please share a link. Any info is appreciated. Not looking for numbers correct just functional pedals. Thank you.
I have a complete conversion less flywheel and clutch.
Transmission, Bellhousing, shifter, console yes 4 speed, hump and brackets taken out
Of a 4 speed car, petals, column. $2000 will be at Carlisle this coming week.
Be advised that there are two pedal ratios available. One for the slantys and another for everything else. If you try to run a 10.5, 3-finger clutch, on the slanty ratio, you will have problems.
Can a slant six pedal be modified to have the v8 ratio?
I’m surprised that you did t expand on that issue.
Would you have pictures to show the difference?
Here is are a few pictures that are not mine, but I have on file showing the two different ones.
The lower one that has the 6" pin to pin arm length in the picture is that preferred one to find....
Below pictures show a close up comparison of the two and there differences.
Thanks for the pictures showing the differences.
What I may add, is that I run a set of pedals from a '75 slant six car in my '74 Dart Sport 360 4 speed with the over center spring removed and a Centerforce Dual Friction clutch set up (diaphragm), and it works perfectly.
All other linkage etc. is bone stock.
Thanks all for the replies and the pictures.
