ok thanks for the infoI would suggest the Mahle power pak with their 1mm ring set, but I do not believe that they have a 340 piston. 060 over
open chamberWhich Edlebrocks; the open chamber 340 heads; or?
ok I will check
yesstandard stroke on the 060 over ?
That’s by the numbers and often is not the case.For a street piston, these may work well for you. Hypereutectic with a deck height of 1.840 will put you .018 above deck, which will help with your open chamber heads. Relatively inexpensive at $390 amazon/$409 cnc motorsports.
Negative is the thicker 5/64th ring pack, but what your 340 originally came with, and they ran well
Keith Black Pistons KB243-060 Fits SB Chrysler 340 Flat Top 6cc Bore 4.100
True that, but since no other information is given to previous block work, it is a starting point.That’s by the numbers and often is not the case.
I have a 1972 340 bored .060 over....Just wondering what type piston everybodys running on the street...Have eldelbrock performer rpm heads....
Thanks ...
