What’s it for? I hope tach connections.?!
Too early for OBD2 port - lol!
Joe
You are sooo right. I’m so deep into this car I can’t see past the windshield.Looks to me for the turn signal switch harness. The 2 green and 2 brown wire are a dead giveaway. No tack wires, sorry!
I saw it after I wrote the post. Sorry guys. Does anyone know where the 4 pin plug is for the tach generator is? I need to check the tach to see if that has the rest of the harness. Time to shut down for the day- I’m smoked.
on a 65 is where your left knee hits the kickpanel, pull it back and you should see the pancake sender and the 3-4 wire harness.
what EFI you running? I sold the 65 tach ($$$) and used a Sun tach in there as it worked with the CD ignition I had.
