What plugs and wires do /6's like?
porksoda
Clovis,NM
Well I am new to these /6 engines and I am wondering what spark plugs and spark plug wires do you all suggest?
(Brand? Style?(copper, platinum, iridium)Gapping?)
I always here about cars running better on certain plugs.
Also while I am here what ignition coil do you all suggest too?
Well thanks for help help!
Any help is greatly appreciated!
Get NGK plugs for a 1996 Dodge Intrepid with a 3.5 Liter, almost any wire would suffice. While you're at it, look into an ignition upgrade. Ditch the pain in the *** points.
well i run autolite 65's (same as a street hemi) gapped at .037 with a petronix ignitor II points conversion and a MSD blaster II coil... all the off the self wires are crappy 7mm wires... there are 8 and 8.5mm wires on ebay for about 40 bucks... ive been running them and have had no issues...
quality plug wires are just as important as the rest of the ignition system.
those napa wires that a lot of people said were great ...actually have around 2000+ ohms of resistance...
msd super conductors=50 ohms
taylor spriro pro's=500
moroso blue max=1200
the ebay ones were 500 ohms i think... i'll have to check again...
2K is a lot:wack:
