What plugs to use
Slappy
Tampa Fla.
Thanks for any input. I am building a 360. Running 10:1 comp just under 500 lift cam , aluminum edelbrock heads. How do I know what plugs to use? If I go to the parts store they just want to sell me the stock spark plug. Not sure about selecting the right one.
I like autolite race plugs 3924.
You might be able to use the 3923 colder plug also.
They have a cut back electrode and are a nickle case plug.
The silver color of the plug helps with reading it for jetting the carb.
-screenshot-2.png[/IMG] (Picture of Racing Copper Core Non-Resistor Spark Plug )
Hover over the image to zoom in
Racing Copper Core Non-Resistor Spark Plug by Autolite - part# AR3924
Part No. AR3924 Warranty
| View Customer Q&A
Be the first to write a review
| View Customer Q&A
Check Availability
Check a Store near you
QTY
No, this part does not fit your vehicle. Change vehicle
Search for similar parts that fit your vehicle
Brand: Autolite
Manufacturer Part#: AR3924
Advance Auto Parts Part#: 15650020
Actual racing spark plug used by some professional drivers. Provides cut back ground electrode, anticorrosive nickel plating and a large ground electrode for improved heat transfer.
