What rad hose for magnum swap
arveeotto
Ontario
I am putting a magnum engine in a '74 Duster and am looking for what rad hoses you guys are using. The local parts supply stores don't seem to keep much in stock these days or I would walk in to see what's close. My combo so far is '01 magnum engine with serpentine belt set up including truck AC compressor, van PS pump/bracket and Champion 22" rad. The rad has inlet on upper left, btw if someone else uses this setup, a belt from a '03-'06 hemi PU works perfect, ordered a few hoses already but nothing works so far. Thanks in advance for any info.
Just an update, the rad I used was a Champion CC2374. Upper rad hose NAPA 8645 fits 92-96 Dakota 318, lower hose NAPA 8920 fits 97-99 Dakota 318/360, with a little trimming they fit perfect.
