mshred
The Green Manalishi
- Joined
- May 2, 2008
- Messages
- 3,269
- Reaction score
- 155
hey guys,
Im going to be running a flywheel from 440source on my 340 and i need to know if the mopar flywheel bolts are 5/16 fine thread or not...i called the dealer and he said that there is no description on thread size and there are no returns on ordered items, so i dont want them to be the wrong ones....i also need 7/8 coarse thread bolts for the pressure plate, but do i really need shouldered bolts? if you guys arent using the special bolts, what are you using? I figure i will need the special shouldered bolts for the flywheel, but for the pressure plate i may be able to get away with regular bolts...any advice on this?
thanks
matthew
thanks
matthew
