Come spring, an index class starts and car must use drag radial. At this point I am using a 7" slick on a 14" rallye wheel. Want to move up to a 15" wheel. How big of a drag radial can I fit w/o moving the springs and using mini tubs?
My '66 Barracuda will take a 235x60x15 on a 7" wheel pretty easily.Come spring, an index class starts and car must use drag radial. At this point I am using a 7" slick on a 14" rallye wheel. Want to move up to a 15" wheel. How big of a drag radial can I fit w/o moving the springs and using mini tubs?
4" on RallysOn that 235X60 radial, what's the backspacing? Thanks
275 r 60 15's fit with no tubing but you have to move your spring perches, and measure measure measure,to get the correct back space on your wheels.Come spring, an index class starts and car must use drag radial. At this point I am using a 7" slick on a 14" rallye wheel. Want to move up to a 15" wheel. How big of a drag radial can I fit w/o moving the springs and using mini tubs?
Is that on a 15" rim? Back space?26x8.5 slick on 7 inch wheel on my 65 Cuda
275 r 60 15's fit with no tubing but you have to move your spring perches, and measure measure measure,to get the correct back space on your wheels.View attachment 1715135124
Keep me in the loop with your results.We're attempting a 15 x 8 with 4.5 back spacing with a 275/60/15 on a 1963 valiant.
Lips rolled and moving springs inward 1/2 - 3/4".
Fingers crossed. Lol
235/60-15 Mickey Thompson Drag radial rolled fender. 15x8235/60-15
View attachment 1715140233 I have been running M/T 255x60x15 on Weld Wheel 15x7/4.5 inch backspacing for 12 years or more with stock spring location and 1 inch lower caltrac mono leafs, with no tire rub at all even with 4 people in my 66 Dart
I'm using P235/60-15 on 15x7" rims with 4 " backspace . Backspaces from 3 3/4 to 4 1/4" will work without problems . Sticky Mickey's S/S radials because I drive on the street . Going to run in 12.50 index and I need another 20 rwhp to get there .
g
oin
