what size of fan blade is on 360 small block ?
More than likely correct across all years.
Here’s a tip, measure the opening of the shroud. The fan should fit inside of that diameter pretty easy without a lot of gap. There will be some gap to allow for engine movement so don’t drive yourself crazy on that.
