What size radials ?
TheKingfish
Member
After I mini tub the 67 Barracuda whats the absolute widest/tallest radial drag or street tire I can put on with no rubbing? Rear springs are Jegs competition. Happy Holidays, TKF
Dimensions on tubs/ spacing added? Relocated springs? Stock rear end width? Disc or drum brake? Wheel backspacing? Wheel width?
A few more details will be needed for this one.
Hi, I'am going to mini tub as wide as I can, right against the frame, and re locate the springs. The rearend will remain stock width. The brakes are drum. The width of the wheels will depend on the width of the tires. Thanks, TKF
Hi
Alright, so you're ordering new wheels AND tires, correct? Unfortunatey, Im not too familiar with the earlier A bodies but I'm thinking you'll max out somewhere around a 10-10.5" wide tire (section width) at around 28"-29" tall. I believe the front of the rear wheel wells (behind the doors) and the wheel lip on the inside of the quarter panel are the biggest limiting factors, but I'm not 100% on this. I'm sure somebody will chime in.
