Ron816
Mopar forever
What is the front wheel stud size for 68 gts with 10 inch drums Small bolt pattern
looks like I need a SBP wheel hubmystery solved I just checked the other 3 hubs they are 7/16
the other is 1/2 looks like someone changed the hub, thanks for the info
left side was the 1/2 studs RH threadLook on the left side 7/16 studs for a L on each. you might still have left-hand lug studs on the left side.
I thought they were 7/16-20 Left hand & right handWhat is the front wheel stud size for 68 gts with 10 inch drums Small bolt pattern
