Retroboy
Hey might sound basic to some of you but what plugs in a 9.5:1 360 with ST21 Racer Brown stick, Vertex maggie, and mechanical injection on methonal?
Cheers
Tony
Cheers
Tony
Cheers
Tony
Hard question to answer definitively. Have you tried anything in particular?
9.5:1 compression ratio seems light for that type of setup. I could be wrong but relatively lower compression on an injected alcohol combo just seems like an odd situation.
Does the methanol make it run cooler? Might want to consider a hotter plug but again, I am really not sure on that.
In any event, can you get Autolite in Australia? #3924 seems to be a popular choice. I use them, no problems. Seemed to work as well as the Champion RC9YC that I replaced. I have a more conventional set up though; approximately 10.5:1 C.R., open chamber iron heads, carbureted on pump gas.
