What tach is this?
convx4
St.Louis Mo
Found a tach and sending unit with these part numbers:
Sending unit 2496162 Tach 2496979
Both applications have a very similar look and may be the same exact tach assembly. The electronic box is the sending unit for the tach. If this is an "A" body tach it is a '64-'65 only. '66's used an integrated tach inside the guage cluster.
No A-body tach in 1964. Check out this thread. It looks like the '65 Formula S may have used the same tach as the '64-65 B-body. [FOR SALE] - 1965 Barracuda Formula S Tach Unit
Jim, The post -link is what has me part hunting. I thought what I found was the tach with out the bezel.
This is the 65 Formula S tachometer and sending unit... looks like yours except for the Bezel and different P/N on sending unit ??
Ah... found your tach... 1965 B Body and C Body "Console" mounted Tachometer!!!
They kept updating the sending unit... just took actual pic of my Original sending unit in my 65 cuda and it has another number ...
First pic is 65 Mopar parts catalog May 65 update !!!
