whats better J or X heads
Mopar General Discussions
  1. dazedand confused
    dazedand confused Well-Known Member
    159
    35
    Oct 3, 2010
    hollister mo.
    Local Time:
    2:38 AM
    So is there a difference between the J heads and the X heads for a low buget performance build ??? I have a pair of J heads with 2.02 valves .
  2. yellow rose
    yellow rose Overnight Sensation
    24,559
    20553
    Jun 19, 2015
    Under The Gun
    Local Time:
    12:38 AM
    Nope. Not a pinch of crap difference.
    • Agree Agree x 7
    • dazedand confused
      159
      35
      Oct 3, 2010
      hollister mo.
      Local Time:
      2:38 AM
      its amazing how people are trying to get crazy prices for X heads? Im starting on a low buget 360 build
      • Agree Agree x 1
      • Treblig
        Treblig Well-Known Member
        6,351
        3502
        Oct 5, 2013
        South Texas
        Local Time:
        2:38 AM
        I've heard of a "pinch of salt"....never heard of a pinch of crap, who would do that???:rofl:
        • Like Like x 5
        • Agree Agree x 2
        • dazedand confused
          159
          35
          Oct 3, 2010
          hollister mo.
          Local Time:
          2:38 AM
          lol
        • 318willrun
          318willrun Utube channel 318willrun
          15,501
          16628
          Sep 13, 2013
          I'm here
          Local Time:
          2:38 AM
          It comes from him dealing with J par for 4 years... :D :D :D
          • Like Like x 2
          • Agree Agree x 1
          • 318willrun
            15,501
            16628
            Sep 13, 2013
            I'm here
            Local Time:
            2:38 AM
            a lot of it is restoration money :)
            • Agree Agree x 1
            • 66fs
              66fs FABO Gold Member FABO Gold Member
              5,014
              1666
              Sep 9, 2009
              Greenwood, South Carolina
              Local Time:
              3:38 AM
              Untouched, X heads are better, by a small margin. Both are good. Ported is how good the porter is.
              • Agree Agree x 2
              • Like Like x 1
              • ir3333
                ir3333 Well-Known Member
                4,707
                1245
                Jun 1, 2008
                ontario,canada
                Local Time:
                2:38 AM
                it may make a difference value wise for a '70 or earlier restoration.They will all support about 400 hp ..even the small 1.88 intake valve j heads and can be had quite cheap sometimes. Get
                an economical valve job you can put together a nice street engine without much expense...and they
                look so much nicer on a stock style muscle car.
              • QuickDart360
                QuickDart360 Well-Known Member
                1,228
                451
                Apr 5, 2014
                San Antonio
                Local Time:
                2:38 AM
                I've seen a flow chart that shows the X head to outflow the J head and other factory heads. So X takes the win.
              • abodyjoe
                abodyjoe Well-Known Member
                20,903
                6190
                May 22, 2004
                Berlin,N.J. 08009
                Local Time:
                3:38 AM
                Did both sets have the same valve size? Some j's Had the same large valves as the X heads. Others used smaller Valves.
              • QuickDart360
                1,228
                451
                Apr 5, 2014
                San Antonio
                Local Time:
                2:38 AM
                Yes it was comparing the 2.02 valved j head and the x head. The j head with 1.88's fared even lower.
              • SGBARRACUDA
                SGBARRACUDA ROY FABO Gold Member
                17,520
                6172
                Dec 7, 2006
                PLANT CITY FL. and PERRY GA.
                Local Time:
                3:38 AM
                I would like to see a bonified flow test that shows a X head in original form that out flows a 2.02 J head?
                • Like Like x 3
                • 318willrun
                  15,501
                  16628
                  Sep 13, 2013
                  I'm here
                  Local Time:
                  2:38 AM
                  basically same head. I doubt there would be an advantage if both had 2.02
                  • Agree Agree x 2
                  • toolmanmike
                    toolmanmike FABO MODERATOR Staff Member FABO Gold Member
                    52,999
                    38489
                    Jan 18, 2006
                    Iowa
                    Local Time:
                    2:38 AM
                    All X heads had 2.02 intakes. J heads had 1.88 or 2 02's.
                    • Agree Agree x 2
                    • abodyjoe
                      20,903
                      6190
                      May 22, 2004
                      Berlin,N.J. 08009
                      Local Time:
                      3:38 AM
                      That's what I was saying.
                      • Like Like x 1
                      • A56
                        A56 MoParAffliction FABO Gold Member
                        1,684
                        1918
                        Jun 24, 2014
                        South of the Mason-Dixon Line
                        Local Time:
                        1:38 AM
                        :thumbsup:
                        even less value than salt?????
                        • Like Like x 1
                        • Agree Agree x 1
                        • toolmanmike
                          52,999
                          38489
                          Jan 18, 2006
                          Iowa
                          Local Time:
                          2:38 AM
                          Let's put it this way, I have heard of X and J heads on the same engine. There can't be that much difference in flow between the two.
                          • Agree Agree x 2
                          • 66jim
                            66jim Well-Known Member
                            530
                            493
                            Dec 11, 2007
                            NE PA ie pennsyltucky
                            Local Time:
                            3:38 AM
                            My belief is the X is more $$ because:
                            The letter X itself id more "exotic" than the letter J...LOL
                            X came on pre emission 340's which carried a "pettigree" no mutts allowed
                            Mopar hoarders have squirreled them for so long they have become Folklore.
                            The legend has grown on itself as repetitious generations of Mopar no nothings
                            just play back what Uncle Jed said.
                            Go ahead and pay more for the golden X it doesn't matter how many tests have proven same as J ...Uncle Jed said.....
                            • Agree Agree x 2
                            • Like Like x 1
                            • toolmanmike
                              52,999
                              38489
                              Jan 18, 2006
                              Iowa
                              Local Time:
                              2:38 AM
                              And how about the Z or O heads. They were the same as the J heads. But the U and some O heads were the 340 TA heads. Just a designation letter.
                            • 318willrun
                              15,501
                              16628
                              Sep 13, 2013
                              I'm here
                              Local Time:
                              2:38 AM
                              put a 2.02 X head on one bank, and a 302 head on the other bank.. that way you have the low end torque covered and the 6k rpm range covered. Talk about street and strip.... :D
                              • Like Like x 7
                              • Agree Agree x 1
                              • toolmanmike
                                52,999
                                38489
                                Jan 18, 2006
                                Iowa
                                Local Time:
                                2:38 AM
                                :rofl::rofl::rofl:
                                Don't say that. Someone will believe it.
                                • Agree Agree x 4
                                • Like Like x 1
                                • MOPAROFFICIAL
                                  MOPAROFFICIAL FABO Gold Member FABO Gold Member
                                  6,479
                                  5435
                                  Jun 1, 2016
                                  Beach
                                  Local Time:
                                  12:38 AM
                                  Check the port volume.
                                  They're are differences.
                                  Floors are different from each other. Took years to notice it.
                                  • Agree Agree x 1
                                  • dazedand confused
                                    159
                                    35
                                    Oct 3, 2010
                                    hollister mo.
                                    Local Time:
                                    2:38 AM
                                    Did not know that on the dimensions on the X heads . Ok well ill have to stick with these J heads since i bought them for $200. For the set with the 2.02 valves. Im going to have them milled down . I will be gasket matching the ports intake and exhaust . The valves will be cut back for flow and polished. Bowels cleaned up.
                                    • Like Like x 2
                                    • Jadaharabi
                                      Jadaharabi FABO Gold Member FABO Gold Member
                                      7,694
                                      8431
                                      Jan 8, 2016
                                      Peoria, Illinois
                                      Local Time:
                                      2:38 AM
                                      If a J head flows 250 cfm @ 400 lift.
                                      and an X head flows 250 @ 400 lift.
                                      Would it matter what letter is on the head?
                                      • Agree Agree x 3
