whats better J or X heads
Mopar General Discussions
  1. toolmanmike
    toolmanmike FABO MODERATOR Staff Member FABO Gold Member
    52,999
    38489
    Jan 18, 2006
    Iowa
    Local Time:
    1:38 AM
    Exactly. I wouldn't doubt they are all a little different. They are a different casting as per the part and casting numbers.
    • Agree Agree x 1
    • 318willrun
      318willrun Utube channel 318willrun
      15,501
      16628
      Sep 13, 2013
      I'm here
      Local Time:
      1:38 AM
      If a X or J flows 250 @ .400, what would matter is I'll trade my Speedmaster heads for them even up :)
      • Like Like x 2
      • Garrett Ellison
        Garrett Ellison Amateur driver on public roadway, do not imitate.. FABO Gold Member
        2,919
        2299
        Jan 1, 2018
        Southwest VA
        Local Time:
        2:38 AM
        Being I didn't build my engine, I have a similar situation, smaller chamber (I'm suspecting early semi closed chamber 273 on right side) but haven't checked casting number yet. 145 PSI cranking pressure right bank and 135 PSI cranking left bank, with the intake closing 107 degrees after BDC. Either that or the right head or deck had a pretty serious cut taken from it. I tell myself that the flow restriction of the semi enclosed chamber evens the power out the output of those higher compression (10.4:1) cylinders to that of the lower compression (9.9:1) cylinders.:rolleyes:
        • Like Like x 2
        • MerlinsMopar
          MerlinsMopar FABO Gold Member FABO Gold Member
          273
          286
          Jun 6, 2014
          Middletown Pa
          Local Time:
          2:38 AM
          You can pop 2.05 or 2.08 valves in j heads also. Same casting. Pocket porting depends on the machinist. I have 2.08s in a set and they are awesome! Your gonna pay to have the work done either way. Depends on what you want. Good luck with your project.
          • Like Like x 1
          • 66fs
            66fs FABO Gold Member FABO Gold Member
            5,014
            1666
            Sep 9, 2009
            Greenwood, South Carolina
            Local Time:
            2:38 AM
            Back in the day, you could tell the difference in power with the X heads. Not much but you could tell. That is why they were prized. No other reason that I know of. Both are great heads, 1.88 or 2.02. X heads only came on 340's. J heads came on any 360s and 71 up 340s. There are/were a lot more J heads out there.
          • SSG_Karg
            SSG_Karg Heeeeeres Johnny!
            1,352
            1214
            Feb 24, 2010
            In the pits
            Local Time:
            2:38 AM
            Still?
            • Agree Agree x 3
            • Like Like x 2
            • Thanks! Thanks! x 1
            • Garrett Ellison
              2,919
              2299
              Jan 1, 2018
              Southwest VA
              Local Time:
              2:38 AM
              AE5FB10D-A3DE-4CCA-8EC8-76299E8F3371.jpeg 9D219429-586F-4917-AA11-6B28FFE48E3B.jpeg Just a quick pic on how not to do it when your installing larger valves, this is a set of ‘73 340 587 heads I’m helping a friend go through.2.02/1.60 installation and new guides. The intake not being blended isn’t as bad as the exhaust, being the charge mixture will tend to jump, but there are still turbulent losses. Leaving the exhaust like this would be disastrous, though. hardened seat installation left a huge step over to the bowl and is going to have to be blended back in. Valves weren’t back cut either, and the valve job is getting a closer look (re-done on a serdi type machine with bowl and chamber cuts) too. It was destined for pure stock oval track use but it looked like they started running out of money after they got so far into the heads. The bottom end is a work of art, though. 0D34A58B-6CEC-4518-99D5-41CC8A73AEAB.jpeg
              • Like Like x 1
              • dazedand confused
                dazedand confused Well-Known Member
                159
                35
                Oct 3, 2010
                hollister mo.
                Local Time:
                1:38 AM
                true
              • RustyRatRod
                RustyRatRod Bla de blizhibliz de blatde blizi bla bla FABO Gold Member
                64,653
                37601
                Jun 7, 2010
                Georgia
                Local Time:
                2:38 AM
                Do you think those are cast in differences, or possibly so small that they are from the molds moving around or some such? In other words, do you think those differences are intentional?
              • RustyRatRod
                64,653
                37601
                Jun 7, 2010
                Georgia
                Local Time:
                2:38 AM
                Yeah some still think the X is worth more.
                • Agree Agree x 1
                • 318willrun
                  15,501
                  16628
                  Sep 13, 2013
                  I'm here
                  Local Time:
                  1:38 AM
                  X is worth more to the restore guy.... To the performance guy, it's a guarantee that they get the 2.02. As far as flow, we could flow two X heads and they would flow differently. Casting on cast heads is far from consistent and perfect.
                  • Like Like x 1
                  • Agree Agree x 1
                  • MOPAROFFICIAL
                    MOPAROFFICIAL FABO Gold Member FABO Gold Member
                    6,481
                    5435
                    Jun 1, 2016
                    Beach
                    Local Time:
                    11:38 PM
                    I think they are cast that way.
                    • Like Like x 1
                    • RustyRatRod
                      64,653
                      37601
                      Jun 7, 2010
                      Georgia
                      Local Time:
                      2:38 AM
                      Ok, cool. Then you think there's enough difference it was intentional. I've often wondered. Thank you drive through.
                      • Like Like x 1
                      • MOPAROFFICIAL
                        6,481
                        5435
                        Jun 1, 2016
                        Beach
                        Local Time:
                        11:38 PM
                        After doing a smooth of the x head bowl it did 226 cfm
                        Now I have a set of 2.02 j heads, stock ...3 angle with the steep bowl cut , no smoothing...and one port does 228cfm
                        It's the in between numbers that are different between them and yes the rest of the ports could be less ,like 218cfm OR near the same in flow.
                      • 12swinger
                        12swinger Well-Known Member
                        425
                        540
                        Jun 26, 2013
                        Hoosier
                        Local Time:
                        1:38 AM
                        The X always seem to have a little smaller chamber, probably a smidge more compression.
                        The J head as a rule I believe had hardened seats in particular the later ones.
                        I always like starting with a 1.88 valve head as you get a fresh seat to work with.
                        I have a set I’m thinking of wrapping up for a 340 build, kind of want a 2.05-1.65 but probably easier 2.08-1.60
                        Anyways I’ve got them pretty much ported and ready except for 3-4 holes in the intake ports I will have a master probably braze.
                        Great head up to around 500hp
                        • Like Like x 1
                        • dazedand confused
                          159
                          35
                          Oct 3, 2010
                          hollister mo.
                          Local Time:
                          1:38 AM
                          Thanks for all the feed back everyone. I was wanting to build a 400 hp 360 . I have lots of old issues of mopar muscle and mopar action but one issue of mopar muscle has an article about a guy that likes to take mostly stock parts and a few after market parts and he made 378 hp with: thermoquad,comp cam , J heads that had a light porting /polishing etc. After market flat top pistons and headers. My project 65 dodge dart 2 door post car weighs in at around 3300 Lbs give or take. I figure for a daily driver and once in awhile to the drag strip on amateur night a mostly stock 360 with performance cam 4 barrel , flat top pistons 10:1 compression , 360 J heads with ports gasket matched valve job bowels cleaned up ,air gap dual plane intake shorty pretzel headers from hedmen headers, 904 with racing guts full manual valve body, 8-3/4 with posi and 3:91 gears should be more then plenty for that little Abody car ?
                          • Like Like x 1
                          • ir3333
                            ir3333 Well-Known Member
                            4,707
                            1245
                            Jun 1, 2008
                            ontario,canada
                            Local Time:
                            1:38 AM
                            keep your compression in the lo 9's with iron heads
                            • Agree Agree x 1
                            • Jadaharabi
                              Jadaharabi FABO Gold Member FABO Gold Member
                              7,694
                              8431
                              Jan 8, 2016
                              Peoria, Illinois
                              Local Time:
                              1:38 AM
                              Why? When 340, 383, 413, 426w, 440 and hemis came from the factory wirh 10 to 12.5 to 1?
                            • 318willrun
                              15,501
                              16628
                              Sep 13, 2013
                              I'm here
                              Local Time:
                              1:38 AM
                              was the gas better in the 60's and early 70's ?
                              • Agree Agree x 2
                              • Garrett Ellison
                                2,919
                                2299
                                Jan 1, 2018
                                Southwest VA
                                Local Time:
                                2:38 AM
                                A lot of users have problems with J heads and compression ratios over 9-1/2:1 with the J heads. Small block Mopar open chamber heads are somewhat lazy during the burn cycle but J heads seem to be the worst offenders whenever someone is having pinging on forum. 10:1 and over is where most people start blending race gas into there premium pump fuel.
                              • 12swinger
                                425
                                540
                                Jun 26, 2013
                                Hoosier
                                Local Time:
                                1:38 AM
                                Gotta run premium.
                                Conservative timing.
                                A bunch of us have the code to get in the gate at the local little airport, 3.97 a gallon for 100 octane LL
                                • Like Like x 1
                                • Agree Agree x 1
                                • MOPAROFFICIAL
                                  6,481
                                  5435
                                  Jun 1, 2016
                                  Beach
                                  Local Time:
                                  11:38 PM
                                  My x heads were 69cc when I got them, stock 2.02 still in them, I ran them that way for a little bit.
                                  My stock original 2.02 J heads , are 72cc fwiw.
                                  • Like Like x 1
                                  • Agree Agree x 1
                                  • MOPAROFFICIAL
                                    6,481
                                    5435
                                    Jun 1, 2016
                                    Beach
                                    Local Time:
                                    11:38 PM
                                    Very true.
                                    Even if its 4 cfm @this or that lift, it's a diff.
                                    Some of the later heads peaked sooner/lower in the lift..which is more usable with the tamer cams of that time.
                                    • Agree Agree x 1
                                    • MOPAROFFICIAL
                                      6,481
                                      5435
                                      Jun 1, 2016
                                      Beach
                                      Local Time:
                                      11:38 PM
                                      The headers are the shortest leash on that dog.
                                      • Agree Agree x 2
                                      • toolmanmike
                                        52,999
                                        38489
                                        Jan 18, 2006
                                        Iowa
                                        Local Time:
                                        1:38 AM
                                        Big time better. Nothing like the puppy pee we have nowdays.
                                        • Agree Agree x 2
