USCG CHARGER
- Joined
- Apr 25, 2007
- Messages
- 2,486
- Reaction score
- 49
This is just a convo piece I wanted to put together just so I can get a ball park figure on what my build will run. I know There will be items that I will have to change and that wont work.
Engine: 416 stroker
R1 block 4.07 bore
4" forged crank
carrillo rods
CP pistons (compression ratio 11:1)
W9 fully ported heads (bench flow number are 380ish)
mild street roller cam specs ? I have to get back with you.
Drive train:
Andrews racing RMVB
Ultimate converter 9" 4500 stall
Suspension:
right now its SS springs but will be chainging them to a Triangulated 4-bar rear susension system next winter http://www.reillymotorsports.com/store/product.php?productid=16172&cat=263&page=1
The front has stock UCA's no sway bar etc.... stock k frame
Frame connectors, chrome molly 8pt roll bar.
REar:
Right now I have a 8.75 with 4.10 gears sure grip 742 case... I will be getting rid of this before I make my 1st pass for sure... to a Dana 60 not sure about the gears though I was thinkin either 4.10's or 4.30's with a 28" tire.
I'd like to get deep into the tens on motor wth this set up then later hit it with a 250-300 shot when myself and the car is ready for it.
Engine: 416 stroker
R1 block 4.07 bore
4" forged crank
carrillo rods
Drive train:
Andrews racing RMVB
Suspension:
REar:
