on a 408. I would guess it would be 1,2,7, or 8 just because they are farther away from the carb. intake is a Air Gap if that helps.
need to get my EGT installed.
thought about shooting each header pipe with a temp gun at idle to see which was the leanest, but that could change at high rpms i guess.
I'm just asking to see if there is a pattern based off of what cylinder you guys have yours on.
thanks for any input.
