Whats-up With My 360?
snoreen40
duluth,mn
I Have A Crate 360 Magnum In My 67 Dart,i Put Flowtech Headers On It, And They Hit Everything,steering Columm,torsion Bar,even My Back 2 Plug Wires Lay On The #2 Pipe,i Use To Have A 69 Gts 340 Never Had This Problem, Do You Have Flaten The Tubes Or Are There Differant Headers That Fit?(no Fenderwell Headers For Me,dont Want To Cut Car Up)whats Up?
new motor mount and trans mount along with the proper plug boot angle will remedy this.
get taylor spriro pro 135* boot wires and then change the mounts I mentioned.
also, you're talking about the driver side #3 pipe that come over and across #5-7 right?
Make sure the engine is located properly.
The tti site has some measurements. I'd check that before throwing money at it.
