It runs and drives with the 3 on the floor and the 170 tower of power. Brakes are sketchy but they work, clutch chatters when you take off, but is fine after that. Engine sounds like a sewing machine. The car feels solid, more legroom than my 68. Looks like the rubber boot is missing on the weird front u joint, the rear joint is a regular cross type. It’s in black primer but it needs major body work I’m sure. I’m kind of afraid to start sanding on it.
