340duster340
Just looking to see what wheel and tire combos you guys are running. Planning on running 15 inch steelies
A few questions, How wide is the steel wheel? What off set? Front or rear or both? Stock hight or lowered? Higher than stock ride hight?
My 63 Valiant I am running steelies from a 84 Dodge Diplomat that are 15x7 with a 4 1/4 backspace. On the rear 205-65-15 and can can go larger(235 60 15 no problem). On the front 185-65-15.I am running the 73-76 a body factory disc brakes with 2'' drop spindles.
The wheel openings are smaller on the 63 fronts and had some rubbing in turns.Your 66 should clear a larger tire. Hope this helps.
One member put on 315's on a early A-body Dart. Not sure if it was a mini tub or just relocating the springs/shock setup. There is a thread on it somewhere. It looks awesome! Makes me want to get'em on my '66 Barracuda.....hmmmm
