Wheel and tire fitment 65 Barracuda
65MagnumFish
65MagnumFish
Zeeland, MI
Hey everyone, I am in need of help. I found some nice rims and tires for my 1965 barracuda. Wondered if the below described will fit or if the backspacing is going to be too tight?
AD: Fronts are 15x6 with 3.75” backspacing (+6mm offset), rears are 15x7 with 4” backspacing (0mm offset) Tires are 205/65/15 and 235/60/15
Any help would be awesome. Appreciate everyone on here.
The math for their offset and backspacing isn't working, but going off the backspacing numbers I would expect these to clear but be close. Worst case, the rear wheels may need thin spacers and you might need a tiny bit of fender rolling.
I was worried mostly about the rear opening because of the barracuda “skirt” look. Rolling the panels isn’t an option. I already have paint and body done. I have a 3 hour drive ahead and thought I’d ask the experts.
Or I was thinking of these …
They are 15x7. 3.75 backspacing and for the rear of the car. I have nice 14x 4.5 steelies that would be for the front. I’d paint them either black or body color. The pic above is a new wheel. Thoughts?
They should fit nicely but I don't have a Barracuda. Those would bolt right on my 66 Dart. 7" wide with a 4"backspace is perfect. Let's see, who runs a early Barracuda with aftermarket wheels?
Or I was thinking of these … View attachment 1716319782
Possibly not enough backspace. @66340SEDAN do you know what difference the rear wheel openings are from Valiant?
My thoughts are good luck finding those in the small bolt pattern. Summit has a few 15 x 6 but none in 15 x 7 and according to Wheel Vintiques, they are not going to sell anymore plain steel wheels in the small bolt pattern.
AP1GczOJJIKTCk91ilFblj0B5tO2rOvbKLs_puZXLXP0O8aXlbRvdNZVvsuovMKLWgs42KHK0d3Tuuq33kFQUomgcXTFGFNTFfx24Wr3zZl8XCMrW7nhOpStiaXCPXRQldFBD7-ZHf_cGfWGA6Mftsr3Zd4e6A=w1405-h1054-s-no-gm
These are 15x7 small bolt Cragars that I ordered from Jegs. Tires are 205/65R15 in the front and 225/65R15 in the rear. No issues. 4-1/8" backspacing.
Think the 15”x6 with the back spacing of 3.75 would be a solid fit for the rear? Just confirming before summit runs out.
15 x 7, 4.25 backpacking, with 24560R15. No problem but my quarters are rolled. Plenty of space to the springs.
