Wheel Bearing Seal - need help
Chargered
New Member
Peosta, IA
Hey guys, need some help. Which way does this seal go? Does the long rubber lip go in towards the bearing or out towards the spindle?
This is the seal for my inner bearing on my front disc brake hub. I got these seals from Dr. Diff for the larger bearing diameter 73 and up rotors.
Small end goes out. I don't think you can even get the assembly together or on the car the other way. The small end forms sort of a slinger up against the spindle.
The spring in on the inside, where the grease and bearings are.
Lip always points toward the lubricant. That's why it's called a grease seal and not a dust seal!!
