[Found!] wheel hub
Pictures of the drum taking off years ago you asked for . This drum was not recently painted. Paint is at least 15 years old I cleaned the back so you could see the condition . It was never cut and no marks , The RH studs are still swedged in. spin the lugs off with your fingers . Original races are still in the hub so you know they are not loose . Shipping would be from 18038 location in my avatar. Original drums like this are hard to find. make me a reasonable offer with shipping. I do not have a drum brake car to use it on. Been on the shelf for a very long time. It may fit in a large flat rate box. I am thinking about $100 shipped to your door. Put new races and bearings in it and install it as is.
Just double checking it is a Small bolt pattern correct?
I have a set of front spindles, bearings, and hubs, with lugs, for front drum brakes. I have no drums. I also dont want to split them up. One is left, the other is right. The left hub has L/H lugs in it. All nice and clean. $100.00 plus shipping.
Pm me if interested, I can send pics.
Dave
