wheel stud flange removal
Double Six
Active Member
Hanceville ,Alabama
Hey guys, I need advice on how to remove the wheel stud flange on the axle. I have never done this so I'm seeking good advise . I am needing to replace the wheel studs.
thanks
Double Six
The axles need to be pulled, and the studs pressed out and in.
Pay attention to the knurl size and length when ordering studs.
Flange? You talking about rear axle? These should not be swedged AKA as in riveted, like some front hubs. Thousands of these have been changed with a hammer. You can pull them back in with spacers / washers and a good nut. Oil the threads up good
