Stacked360
- Joined
- Mar 9, 2009
- Messages
- 195
- Reaction score
- 4
I relocated the spring perches on a 67' B-body 8-3/4", and pressed out the wheel studs as I didn't want to deal with the LH threaded side, and wanted both to be the same so I pressed the other side out as well. I have an alterkation front suspension, and want the rear wheel studs to match the fronts, so I measured the fronts and came up with 1/2"-20 studs that are 1.75" long under the head. My rear rotors are 1/8" thick, so what I need are press in studs 1/2"-20, 1.9"-2" long under the head, and a .670-.680 knurl diameter...I cannot find anything even remotely close to this size. Closest I found were 3.5" long, does anyone know where I can get wheel studs close to that size?
Thanks in advance.
Thanks in advance.
