I'm putting on some 17" Bullet wheels on my 70... Duster with front 73+ disc conversion. I need a 1/4" to 3/8 inch spacer to make them work on the fronts. Now I need longer studs. I can get the lugs to engage for a few threads, but another 3/4 to 1 inch would be perfect as I can use the existing lugs I have.
I've been looking online at so many, that I'm dizzy thinking about what may or may not work. I saw some Mopar, mostly for back wheels and drum brakes, but the knurls are a narrow band maybe a 1/4 wide on the shoulder where as the one I removed from a rotor in my shed has a knurled shoulder about 5/8 wide so it engages the both sides of the thicker disc rotor. I'm not lazy and am trying to do the work and see some late model Ford , Dakota and Jeep studs that might do it, but I'm hoping someone here has done this and might know a part # that will work for this situation. Thanks
