O oldkimmer FABO Gold Member FABO Gold Member Joined Nov 11, 2006 Messages 24,807 Reaction score 8,931 Location Kindersley, Saskatchewan, Jul 25, 2024 #1 Hi there has anyone put the 2009 chrome 8 bolt Dodge 3/4 ton 17 inch rims on to a 2006 gmc 3/4 ton that has 16 inch rims. If so do they fit good. I’m not sure if the 8 inch rim would interfere with the top ball joint. Thanks. Kim
O oldkimmer FABO Gold Member FABO Gold Member Joined Nov 11, 2006 Messages 24,807 Reaction score 8,931 Location Kindersley, Saskatchewan, Jul 26, 2024 #2 Wow, no one with any info. I’ll try google.
diymirage HP@idle > hondaHP@redline Joined Oct 12, 2012 Messages 35,300 Reaction score 48,135 Location michigan Jul 26, 2024 #3 Conventional wisdom would say that a larger rim should clear (especially when going from aluminum to steel) Is the Dodge rim wider too?
O oldkimmer FABO Gold Member FABO Gold Member Joined Nov 11, 2006 Messages 24,807 Reaction score 8,931 Location Kindersley, Saskatchewan, Jul 26, 2024 #4 17X8 dodge. 6.5 gmc
diymirage HP@idle > hondaHP@redline Joined Oct 12, 2012 Messages 35,300 Reaction score 48,135 Location michigan Jul 26, 2024 #5 Then the next thing to consider is backspacing If that is the same you should be golden (and the added 1.5 inches poking out will look awesome)
O oldkimmer FABO Gold Member FABO Gold Member Joined Nov 11, 2006 Messages 24,807 Reaction score 8,931 Location Kindersley, Saskatchewan, Jul 26, 2024 #6 From what I remember more backspace on the dodge rims. I’m thinking they will be in an inch or so.
O oldkimmer FABO Gold Member FABO Gold Member Joined Nov 11, 2006 Messages 24,807 Reaction score 8,931 Location Kindersley, Saskatchewan, Jul 28, 2024 #7 It’s a no go. Dodge 6+ backspace. GMC 3.5 back space. I only have about an inch between the rear wheel and the spring. Kim
diymirage HP@idle > hondaHP@redline Joined Oct 12, 2012 Messages 35,300 Reaction score 48,135 Location michigan Jul 28, 2024 #8 Shoot, that's a bummer
O oldkimmer FABO Gold Member FABO Gold Member Joined Nov 11, 2006 Messages 24,807 Reaction score 8,931 Location Kindersley, Saskatchewan, Jul 28, 2024 #9 Yupper it is.
