wheel tire combo help?
dust-u
I just got a good deal on some torque thrust wheels 15x8.5.. Has anyone been able to squeeze these under a duster..? If you have what tire size did you run.. any info. gladly accepted...whoops backspacing is 4.5...
I have that size centerlines on my duster with M/T drag radials 275-60-15 and they fit in really nice....BUT I have the offset spring kit that moves the spring over 1 inch on my car. I only have 1/2" from spring to tire. You're gonna have to use a really narrow tire (2 inches less total width than mine) to get the same clearance to the spring. Either that or offset or inboard your springs. good luck.
