wheels and tires on a 72 demon
mrdemon72
Member
i have a 1972 dodge demon with a dana 60 12 inch willwood brakes on back. i also have 10 inch willwoods on front. i need to know what size rims and tires will work on this car. does anyone know what back spacing would be? what rims would look good any suggestions
I guess a lot depends on where the axles ended up in comparison to the originals. Is everything back in it`s original place? If so (and the car is not tubbed) I would guess a 275/60-15 would be about all you can get under there without tubbing or moving the springs. I like American Racing wheels! :D
from my leaf spring i have for 4and7/8 to mounting surface and 6 inch to inside lip of wheel well what would be my back spacing and would a 15 inch rim fit over the 12 inch rotor. what size rim and tire thanks
