wheels for dart?
mopars
Toronto, On
Hello
I"m looking to put a 245/60/15 wheel (15*8) with a 4.5 back spacing on a 67 dart with a 8 1/4 rear end and no change with the springs. Will this fit and I"m really curious on what i should run for the front i have no clue, I was thinking like a 215/60/15 but i dont know about the back spacing and what size wheel.
Thanks and any imput would help alot!
The only guidance I can give is from my 71 dart. I dont imagine a whole lot is different clearance wise. I have 15 x 7's on the back with 4.25" of BS. I wish they were 4.5. I can fit a 245/60 on there but I had to roll the pass side fender because the axle wasnt perfectly centered. (8 3/4) I am running225/60's in the front on 15 x 7's also, same BS. Had to trim a little at the bottom front edge of the fender but very little. Hope this helps you out some.
Mike
