Wheels & Tires For Sale: Local Pick up only!
Demon 408
Hampton Roads, Virginia
Tires are BFG 255/60-R15 and 225/60-15 with a lot of tread wear remaining. Wheels are Centerline Convo Pro with satin machine center and polished outer and 5x4.5” bolt pattern. Two 15x10 with 4-3/4”backspace and two 15x7 with 3-3/8” backspace. Center caps and lug nuts included. Located near Williamsburg, Virginia, will deliver up to 35 miles. $599.00.
Were these mounted on a Demon? If so I would like to know how they fit. I'm trying to find out how the 15 x 10's fit & look under the rear with a standard 8 3/4 for an a-body. Do you have any pictures?
Thanks
TAZZ
They were mounted on my Demon, but I have a B-body 8 3/4 rear so they stick out more than they would with an A body 8 3/4 (see picture). I also have the leaf springs offset (adds about 3/4 inch additional clearance) so my tire to spring clearance is 2 1/4 with these wheels and tires.
tires are bfg 255/60-r15 and 225/60-15 with a lot of tread wear remaining. Wheels are centerline convo pro with satin machine center and polished outer and 5x4.5” bolt pattern. Two 15x10 with 4-3/4”backspace and two 15x7 with 3-3/8” backspace. Center caps and lug nuts included. Located near williamsburg, virginia, will deliver up to 35 miles. $599.00.
priced reduced $499.00
shipping would be killer would love to have them
just the\set u i am looking for
I sure would like to trade u just the back wheels, mine are 8.5''[yes they made them] have both 4.5 and 4.75 dual bolt pattern, same wheel..convo-pros...new just been mocked up in shop,narrowed rear so now could use wider rims,dont need tires caps or lugs.....???
