'Wheely Cool' Mopar shop shelving you can make yourself.
Alaskan_TA
PA
'Wheelly Cool' Mopar shop shelving you can make yourself.
I used;
8 - 14" wheels.
6 - wheel covers & 2 hubcaps.
A few assorted used emblems.
4 - 2x6x10's ripped to fit inside the inner wheel beads.
4 - 2x8x10's tops for shelves.
2 1/2" screws & construction adhesive to laminate each shelf together.
1/2" Ready rod, nuts & washers to secure each wheel to the cinder block wall.
(interior wall in my case, so I left the ready rod long so I can duplicate these on the far side as I get more wheels & caps / covers)
Very cool! Overbuilt probably unless you are planning to store engine blocks on it! But still very cool!
C
That is a great idea. The coolness factor is over the top.
Only problem I see is that when the shelves are full,the damm thing rolls away,mrmopartech
They are through bolted with nuts for the wheels & on the far side of the cinder block wall so they are not going anywhere.
I left the all-thread sticking out far enough on the other side to repeat the process when time allows it.
