Where does this go ?
awg329
Grand Island, Nebraska
Restoring a 1976 duster. Installing interior and trim. Where does this part go ?
Sill plate extension from the rear of the door opening to the rear seat area / side panel.
Just above where the front seat belt lower anchor spool is. It runs horizontally to the front end of the rear seat bottom cushion.
And there are two different kinds of screws for that IIRC; a special one with an integrated washer,that is serated on the underside to be installed at the joint; and a bright plated ovalhead at the other, that fits into the depressed hole. Both Phillips
