ronnysplymouth
Member
Where is the cheapest place to buy Edelbrock heads for a Big Block ???
GEESH, I have asked on other forums and all anyone ever tells me is get eddy heads..................everyone (except you) says iron heads suck...........so here goesMrmopartech said:Why do you think that eddy heads would be best for you.As you can save more money and get more from a iron head!You need to state your combo and the RPM range you intend to run in and your driving style and the type of cam you intend to run to pick the head and runner you need for your motor.BJR,has heads in stock,and the style you might need,if you put up for us your motor build you are doing,and if its for the street or strip.
BJ Racing 1-770-955-0659
Mrmopartech
ronnysplymouth said:Hey Demon seed, can you lay out your complete combo?
Is there a thread on here about combos for 440 a bodies?
why? if the eddys were no problem and were quicker? will have to check the number on the rods....................Dropping heads off tuesday for machining66dartman said:went .6 quicker with the eddy's over ported 452's and have had no problems with them. Now I want to take them back off and put the 452' back on.
