I cant believe how hard this is to get new rotors. Everyone sells a (behind the hub) but no hub. Mine are one piece. these are stock 11'' 5x4 rotors. Any one have a link. None of the part stores list them.
"Stock" Factory, 65-72 Kelsey Hayes rotors, are two piece.
Rotor and hub.
Modern replacement rotors, are a rotor only.
They DO NOT come with a Hub.
You are supposed to take off the hub from the old rotor, and then install it onto the new rotor.
Sounds like you don't have Hubs.
In that case your likely SOL.
Hubs are unobtanium, obsolete, dinosaur eggs, hens teeth, to find, and then purchase, in this day and age.
People threw out their old rotors with hubs still attatched to them, and that's a reason why just hubs are so damm difficult to get ahold of.
As you already found out, you can get rotors alone, from vendors, sellers, on Amazon, or Rock Auto online.
You can convert to big bolt pattern by using Ford Mustang rotors, that are machined to work on the Kelsey Hayes spindles, and those are a one piece rotor and hub assembly.
But again, if your looking for hubs, i wish you lots of luck.
I needed a pair of hubs for a customer of mine, and took lots of time and effort, before i ever located a pair of them, on this web site.
I probably depleted the stock of them, out there in the nation. lol
