It's probably too late to respond to you, but in case someone else is curious...
Those nylon wiper linkage bushings are also found in the HELP! section of most auto supply stores.
To make them easier to install, soak them a while in VERY HOT water to soften a little, pat them dry, and press them into the linkage with pliers / channel locks. Don't forget to load up the "cup" with white lithium grease, before you snap everything together.
Jerry
