I'm in the process of rebuilding my 273 HP. I'm confused on where to measure ring gap in the cylinder bore. The factory service manual says to measure 2 inches above the bottom of the cylinder, but I've read other articles that says to measure 1- 1 1/2 inch below the top. When I measure according to FSM the gap is within specs, but when I measure 1 1/2 below top, the gap is at .020 to .021 on compression ring and the oil rails are over .055. Any clarification would be greatly appreciated.
