he does not want to buy pistons
just rebuild one of the motors he has
that may not work
if neither of the block will work with just a hone and rings he has some decisions to make
go pick on will it run
What is “Go pick on will it run?”
If you think I’m picking on you well then you are certainly delusional.
With his engines and what he stated he wanted to do, it is a gamble, period, So is a junk yard engine of any make model and year bar none. While modern ones are a good to great bet, it is still money spent that may not be needed or a route he wants to take. He wants to try and just do a re ring job. While this may or may not work, this remains to be seen. I’d assume any engine I get needs to get a bore enlarged.
post 1
"Ps budget build so rebuild will mean gaskets all around mild cam and upgrade intake and new rings"
and rumble talks about a performance rebuild
what's your plan B rumble if both his blocks have huge ridges?
I do not talk about a performance build here but you ALWAYS push a large aggressive cam...
Hypocrite! And Delusional on your behalf. If there was anything race oriented, it was your mention of 60 foot times.
You wrote “Pistons” and I gave my reply on what I would do which depended on the type or goal of the build. One slug could be used for stock replacement / upgraded or light race and the other would be a race slug.
That was an answer to you and not a suggestion to the OP
My plan “B”?
I don’t need a plan B because I would assume it needs it even before I look. I’d hope it wouldn’t need it but if it did, It would just be part of plan A.
Wyrm trips on acid.... Constantly!
ruble misses the point, right over his head
Pot calling the dish black. Wake up brother! Wake up!!!! The only thing semi over my head is your replies looking like incoherent babble.
Also spell check.....
of course it should be but his definition of rebuilt is new rings not your definition of standard practice
What the fudge are you babbling about?
Jesus H Wyrm!!!!!!!
Are you even awake? Reading the same thread.
What freakin planet are you eating mushrooms on bro!
WTF?!?!?!
You really need to proof read your post and organize your thoughts into a coherent paragraph.
Not my definition? Wake up! I never gave it!
Been rebuilding engines for 34 years now without failure thank you very much. I am sure how to get it done and yet you throw stones like a child. Mental check yourself dude!
If your not going to help the OP rebuild the engine of his choice, then why are you here?
I go into every build expecting a bore job and new pistons. its all but automatic.
Dang skippy!!!!
But always hoping for the best.
