1stBxMopar
Anybody want to say before I install and check which one of these two cams will have the most or the least piston to valve clearance.........
440+.040
Ross pistons #99782 14cc Domes
"0" Deck at TDC
1ST. CAM-
Comp Cams- Part #23-630-5 Solid Flat Tappet (Grind #CRB3 324A-8)
Lift-.650 in - .650 ex.
Advertised Duration- 324 in.- 324 ex.
Duration @.050- 290 in. - 290 ex.
Lobe Separation 108
Intake Centerline Installed 4* adv. @104
2ND CAM-
Lunati- Part #53712LUN Solid Roller (Grind #RRG-312-320)
Lift-.690 in. - .690 ex.
Advertised Duration- .312 in.- .320 ex.
Duration @.050-.276 in. - .284 ex.
Lobe Separation 106
Intake Centeline Installed 4* adv. @102
Anybody want to say which they think will be the tightest piston to valve????????? :-k
440+.040
"0" Deck at TDC
1ST. CAM-
Lobe Separation 108
2ND CAM-
Lobe Separation 106
