which carb would you run?
Fuel and Air Systems
  1. BARRACUDA340S
    BARRACUDA340S Well-Known Member
    1,011
    0
    May 13, 2004
    MT PLEASANT IOWA
    Local Time:
    12:57 PM
    I sold the Pro Systems carb sun. I'm going back to BIGS. I talked to Jessie today and we were bouncing some ideas around between a 950 stage 7 and a 1050 dominator stage 7. Scotty loves his dominator from Jessie and Scotty's picky, so it's gotta be right. Jessie made me a no risk offer, if I don't like the dominator he'll switch me around to a 950. I would only have the added expense of throttle bracket and spacer adapter and base plate for air cleaner. Many guy's with the strokers said they picked up a 1/10th or better going to the dominator. Keep in mind I have a 4 speed car with 4.10's. Here is my set up
    416 small block
    12.4 comp
    Indy 360-1 single plane intake
    Indy 360-2 CNC'd heads
    cam solid roller 254/266 621/624 112 lobe 108 center
    TTI steps 1 5/8 to 1 3/4
    x pipe exhaust
    4 speed car wieght 3420 with driver
    4.10 gear with 28" tire
    chasis dyno numbers with a stock BG 1000 race demon
    head flow numbers
    head flow #s
    .200 150.1/100.1
    .300 210.5/146.6
    .400 253.6/208.4
    .450 278.4/226.0
    .500 294.3/235.3
    .550 310.2/244.3
    .600 320.2/248.4
    .650 329.8/255.3
    .700 334.7/259.4
  2. Jason96R
    Jason96R Well-Known Member
    266
    5
    May 22, 2004
    Ohio
    Local Time:
    7:57 AM
    Honestly what I would do is to tell Jessie my car/engine specs, I know you have, tell him what the cars intended use is and let him make the decision. The way I look at it he knows alot more about carbs and all of that then I will ever know. Those dominators do look cool though especially with the different colors he has.
  3. BARRACUDA340S
    1,011
    0
    May 13, 2004
    MT PLEASANT IOWA
    Local Time:
    12:57 PM
    he has all the specs and because of the 4 speed we aren't totally sure how the dominator will work. I really want the dominator because I know the motor will like it upstairs, just not sure how it will react on the bottom. My only experience with this set up was with the pro systems and I think he missed the set up
  4. mikesduster
    mikesduster Well-Known Member
    1,630
    3
    May 12, 2004
    Winter Haven,Fla.
    Local Time:
    7:57 AM
    DOMINATOR!!!!!
    they respond VERY quickly!!!
    dad ran one on his indy head 440 and loved it!!!
  5. rabius75
    rabius75 Well-Known Member
    543
    1
    May 22, 2004
    Dallas, GA
    Local Time:
    12:57 PM
    *sniff*
    im so poor!
  6. turbodart
    turbodart Well-Known Member
    93
    0
    Oct 3, 2004
    Albany NY
    Local Time:
    7:57 AM
    domnator---even with a 4-speed you'll still like it. custom carbs make such a difference over an out of box deal if they are done right. i have heard great things about BIGS, a friend has been talking to them about a 1050 for his car (440 gtx)
    --chad
  7. cuda66273
    cuda66273 Well-Known Member
    251
    21
    May 22, 2004
    Oregon
    Local Time:
    12:57 PM
    I don't undestand why you just don't Tune the Race Demon?
    It's really a little too big for your application you should probably have used a 825 GC or the 875 RS model.
    We run a 995RS on our 445 CID Dart at 9.70's 138 MPH, we tried to bump the sleeves to a 1050 and it slowed by .2. We had a 1050 Dominator on it and the best we ever got was a 9.94.
    I just can't believe that a Race Demon 1000 or a re-worked 1050 Holley will be optimum on that engine, maybe for a Dyno pull which is worth the recycle value of the paper. In the real world when you bolt it between the fenders the smaller carb properly tuned will produce a quicker time slip.
    We run a 650 Race Demon on the 318, properly tuned it gives us very low 11.60's/115MPH at 3100#'s.
    My Buddy's 548" BB Chevy uses a 1050 Brazwell carb and runs 9.40's.
    Our 451 utilizes a 825 Mighty Demon and runs low 10's...just some examples of carb to engine sizing.
    Too bad you wern't closer I'd get that Demon dialed in for you. I can see what's wrong with it by looking at the Dyno sheet.....mid range and Hi-Speed bleeds are too small.
