Which Coolant?
67_Slimer
Real Hot Rods don't shift themselves.
USA New England
OK! Probably was viewed so many times but I'm just curious and need a 100% accurate answer. Which coolant do I use in my Aluminum headed/Aluminum Radiator 340? Seems like there's a red coolant in there now but it's due for a change plus I'm replacing my water pump and hoses. I want to make sure that it's good for the block and the Aluminum heads/Radiator. I plan on flushing as much of the old stuff as I can. Thank you!
We use the red / Asian coolant in the race cars cus when diluted it looks like water wetter in the overflow. All are about the same. So pick one and stick with it
I would look at what the modern AL FE engines are using.
